Old 5th March 2012, 07:17 PM
SilverS8 SilverS8 is offline
Use heat.. gets them easily
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 9th March 2012, 06:15 AM
gapthree3 gapthree3 is offline
Default S8 Springs & things
Double bugger. Despite 4 days of penetrating fluid and applying the blow torch I now have the remains of 2 sheard bolts wedge in the uprights. It's official they are stuck fast and not coming out. I now have to firk out £720 to Audi purely for there design flaw and buy 2 new uprights. I don't mind spending money to see an improvement or upgade but this takes the biscuit.
Ebony Black D2 S8 with parchment leather and 190K miles rising fast!
Old 9th March 2012, 06:59 AM
Have you checked with A8parts to see if they have any in?
Old 9th March 2012, 08:33 AM
Dave@A8parts Dave@A8parts is offline
Staff at A8 Parts
We have most parts available however we don't currently have the uprights in stock.
As with the age of your car being a 2001 S8, you will have the larger 360mm Brembo brakes so unfortunately the hubs carriers are different.
If there is anything else you need for your car please give us a call on 01642 783537 and one of our team will be happy to help you.
At Work to Drive:
2013 VW Caddy 1.6TDi Bluemotion, Highline, Heated seats, winterpack, DAB, Bluetooth, Lift up Tailgate, Colour coded, Leather wheel and gearknob, RNS 510 Touch Screen, optical PDC, HL Wash.
1997 S8, Pearl White
2005 W12 6.0, Heated Ventilated Massage Seats X4, Glass Sunroof, Fridge, RSE, Bluetooth, AMI, TV, Enhanced Leather, Heated Windscreen, 20" Alloys, ACC, Auto Boot, Soft Close Doors, 3 Electric Blinds, TP Monitor, Fingerprint
Old 3rd April 2012, 08:59 PM
Well after major wallet surgery I go the old girl back. All clunks bangs & wonderings have gone....along with about £2k! Thank you Audi for your £700 design fault! So Steering, goes where its pointed and is no longer restless or wondering. I had got used to almost constant correction at the steering wheel and now it's gone it's so much more relaxing to drive. The feel is linear and positive and any hint of tramlining has gone. The front bilstein B6's are excellent. On the motorway they have the same level of comfort as you would expect OE. On A & B roads they are supple but controling. Only on badly pockmarked bitumin is there any any hint of harshness but control is total. There is a B road near me that at 100 (Can't recall MPH of KPH) would see it jump 6" offline on the straight at one point. Now it sails over it with millimetric precesion and a controlled ride. Body roll has gone and the occasional ABS light on hard braking on bad bumps has gone. I tried by hand the old 192K oe shocks and was impressed they still damped both up and down but no where near the virtually unmoveable B6's. I have to say I occasionally note that the recent OE rear shocks I had fitted not so long back can be felt moving about at high speed on bad undulations. Not much but enough to make me wish had gone with B6's at the rear for the same cost. I've already done nearly 800 miles on the new set up and well impressed. Next stop new springs, then maybe subframe mounts in the distant future. I had a new sub-frame fitted to a 110k D2 4.2 sport 6 years ago on insurance as the previous owner had decked it and it would not align up. The NVH reduction was amazing. She needs to earn her keep until then, here's hoping.
Old 11th June 2012, 04:32 AM
adjuster adjuster is offline
Any updates on the new shocks?
Part numbers for the B6 front shocks would be great too, as in the USA, they only list the B6 shocks for the rear, and two HD ones for the front.
Thanks in advance.
PS: I'm looking to see if some polyurethane ARB bushings are possible for the S8. This would be a nice upgrade for most as it firms up the ARB response, but does not make the ride harsher.
They do squeek however, so a good marine grade grease up when you install them is the only way to go. (Many come here with a little pouch of grease they reccomend, Suspension Techniques does this for example.)
Old 11th June 2012, 04:54 AM
Mike and myself talked to Polybush at GTI international last year http://www.polybush.co.uk/ to see if they could put together a kit for A/S8's - not sure where that's at but I'll ask if he had any more contact with them. We are there again in a couple of weeks so might be an opportunity to see what they can do. I have a complete set of spare arms for my 8 from when I changed all the bushes not long ago so might be good to give them that set cleaned up to see what they can put together and use it as a "stock set" to save people taking theirs off and waiting etc.
