D3 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
Current Wheel Specs
Width 9" Offset 44 mm New Wheel Specs Width 8.5" Offset 35mm Results Inner clearance 15mm more (This means the wheel is 15mm further away from the suspension on the inside) Outer position 3mm further out (This means your wheel will sit out 3mm further out on the outside edge) (would be a bit too much I think) All this is assuming that the wheels are 8.5J rims
. Nite Blue 3.0L SE Quattro |
