Old 20th March 2012, 09:56 AM
Contact Audi HQ and ask them why there is no warranty on a new £22k engine and tell them about the faults you have found.
And then make plenty of space in your garage.
Dezzy got a case of wine for not even managing to spend £2.50 on a part. Imagine what sort of customer care you'd get for a problem with a £22000 flagship engine change....
Old 20th March 2012, 09:58 AM
In all seriousness though - Yes, I'm sure the extended warranty ended, and thus so does the liability for fixing the car, however Audi UK or their associated insurer coughed up 22K to Wakefield Audi to do the job right. I'm sure Audi UK would have some influence if it had genuinely not been done correctly.
Old 20th March 2012, 09:59 AM
Mmmm now your talking, i will google the number and give them a call i will let you know how i get on
Old 20th March 2012, 10:10 AM
So there is no mention of the small job of the engine replacement in the service history? Or is it one of those jobs like just topped up the washer fluid so didn't mention it?
Would it be documented anywhere why the old unit failed?
Anyway Guy atleast you know that it has a new unit and with care and maybe servicing yourself so you know it's actually been done she''ll be good for many years to come.
Also as said abouve well worth winging to HQ as it's now a trust issue and you don't expect main dealers to bodge it up
Old 20th March 2012, 10:12 AM
True. It was the best £2.50 i've never spent
Old 20th March 2012, 10:23 AM
Glync's Avatar
Glync Glync is offline
Perhaps this has no relevance but I was told and had it confirmed in email all Audi replacement parts are covered by a two year warranty so surely that a least applies? I double checked this when I swapped out the air compressor and kept the email for good measure!
£22,000 is one hell of a job and regardless of change of ownership should have some warranty cover even if you wouldn't want them near I again!
no there is no documented evidence of the engine change seems it was swept under the carpet
well if thats the best 2.50 you have ever spent then im sure that this will be the best phone call ive ever made as the 20+k for an engine swap must be worth at least a box of wine
Old 20th March 2012, 10:39 AM
If *you* pay Audi with *your* money to do a job, it is warranted for 2 years.
If its done under warranty, that part along with the rest of the car is warranted until the warranty expires...
Otherwise, if a car had an unreliable part that lasted only 18 months, they'd be changing them FOC for life !
Old 20th March 2012, 11:12 AM
What a result!
Guy you must be one happy guy, you effectively have a brand new car!
Old 20th March 2012, 11:18 AM
47p2's Avatar
47p2 47p2 is offline
....is that its only 1 owner from new and he was the Audi garage owner ?
That could also explain why some faults were not rectified after the refit...
Nite Blue 3.0L SE Quattro
