D2 - Common Faults Quick links to all known common faults and their solutions |
If it's not doing it on the PF (and you do have to literally floor the throttle in tip), then you may have some slack in the throttle cable, check and see if you can adjust it where it meets the engine.
The easiest way to test kick down button:
1. Car is parked. Gearbox is in "P" position. 2. Ignition is OFF. 3. Marker lights are ON, all buttons are lit red. Push accelerator pedal and press kick down button. "+" and "-" LEDs on the gearbox panel will switch to full power (just like in Tiptronic mode). Release kick down button. "+" and "-" LEDS return to half capacity burning. The above procedure only works when gearbox is in "P" position, only with ignition OFF, and only when marker lights are ON.
I'd rather drive on left |
What are the 'marker lights'? I tried this with the ignition on (but engine not running) and it seemed to work. Initially nothing, until I turned the kick down switch on - then it did just as you said.
Lights stalk one step up ![]() >> I tried this with the ignition on (but engine not running) and it seemed to work Interesting. Perhaps I didn't notice something ![]()
Marker lights are simply having your lights set on the sidelight setting / sidelights on Jim, so that the switchgear all glows red
Yes, it works like Sergie said. Mine was switched off - can't wait to give it a try!
Mine has got to be turned off as it won't kick down. Ill be checking this in the morning and hope that its just in the off position.
Tags |
facelift a8 d2 kickdown |
