Old 2nd April 2012, 08:56 AM
I dont know if its going to help, but when my battery went flat, I had similar warning lights, ABS, ESP, those systems seem to go a bit crazy on low voltage. Also the dash pannel was very dim and fading.
Also for replacing the auxiliary belt, I think its quite easy, I took mine off the crank pulley and the tensioner without removing anything (to check if a squak I had was the auxiliary belt or the timing belt).
I think, although dont quote me on this, that you can even manouver the new belt around the fan, I dont think you need to take the fan off either.
Old 2nd April 2012, 08:28 PM
When you mentioned the metal hoop that rang a bell in my head.
Around 6 months ago I too found a metal hoop on my driveway, couldnt figure out how it got there but it never really occured to me it could be off the car. I still have that hoop, here is a picture. Did the hoop you saw look similar to this?
Can anyone solve this hoop mystery?
Old 3rd April 2012, 06:40 AM
plankton plankton is offline
Yes the hoop was like that, but it had snapped. Wonder if that's related then
Thanks for the replies so far - not heard back from the garage yet. I just told them to fit it in when they could.
Kev
1999 4.2 V8
2008 Saab 9-5 TiD Estate 185BHP - long gone. The Merc E250 that replaced it has gone too.
Old 3rd April 2012, 06:46 AM
Nollywood's Avatar
Difficult to work out the scale of that steel hoop. Is it small enough to be between the belt tensioner and its bracket?
Old 3rd April 2012, 06:49 AM
Could be part of a fan shroud perhaps? Maybe ripped off when the belt exited?
Because these belts are so long you can be unlucky and find it takes out other things when it gets caught up after snapping. If it just gets fired off then shouldn't be a major problem to sort
Old 4th April 2012, 07:51 PM
Its 35cm diameter.
I cant find anything that looks like it on VagCat, at least not to do with the fans, or the gearbox or anything else round on the car that I can think of. Could be just a strange coincidence that we both found a similar hoop near our cars.
Maybe its just a bin liner hoop issued by the council and there are a lot of them around?
however the council bins around here are square so that wouldnt make sense
Old 4th April 2012, 09:11 PM
Its 35cm diameter.
My first thought was that it was for a bin to keep the bin bag in. Bit weird if it isn't anything to do with the car though
Kev
1999 4.2 V8
