Old 6th April 2012, 09:57 AM
Which version of Android do you have on the phone Tony?
Has the update sorted it? Though I'm also discovering the joys of the crap iPhone 4 connectivity to the later bluetooth kits.
Old 6th April 2012, 09:59 AM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
Got the phone connected now, but no phonebook import option
Going to try a couple of things:
1. Remove pairing from car & phone.
2. Reset Telephone module.
3. Re-pair phone to car.
Will let you know how I get on, as gotta take girls out now
A8OC Founder
The A8 Owners Club here
Old 6th April 2012, 06:26 PM
A8_Tony's Avatar
Well that didn't bloody work!!
Frustrating as hell, might have to try my Desire HD and see if I get the same issue. If I do it's likely to be OS/Contact storage related. If not it's down to the phone gggrrrrrr
A8OC Founder
Old 6th April 2012, 06:48 PM
What you need is an rSAP adaptor!!
Ahemmm I happen to know someone who has one
Old 8th April 2012, 09:06 PM
A8_Tony's Avatar
Unfortunately Neil, the rSAP adaptor would not be useful for me. Android phones apparently don't have an rSAP protocol built into them.
However, I've fixed the issue now, deleted my call logs, and job's a good 'un
A8OC Founder
Old 8th April 2012, 09:40 PM
I thought Android did rSAP too.. The only saving grace of rSAP is a better quality signal in marginal areas (like the bloody M8!!) as it uses the car's antenna instead of the phones.
Old 9th April 2012, 07:02 AM
rSAP is more a function of the particular phone than Android or not Android - and usually down to which manufacturer makes the phone. Just check out the phone spec on the manufacturer details.
Remote SIM access profile Bluetooth adaptor cradle.
An enhancement of the factory-fitted option "Mobile phone preparation - Low". It enables mobile phone handsets to connect to the phone preparation via Bluetooth Remote SIM Access Profile (rSAP). When handsets are connected, the cradle enables the use of the external GSM car antenna and deactivates the handset antenna in order to minimise GSM radiation in the car and handset battery consumption. The handset is put into standby mode so battery power drain is minimal. Once connected, the cradle connects to the handset automatically and details of up to four handsets can be saved. Only handsets with Bluetooth rSAP functionality are compatible with this adaptor.
