Its hard to believe but the wiring is totally unprotected going into the connector and will just drain water into the connector. I will look at some similar method of protection.
Update on my headlight issue. The link-arm from the front level sensor had detached from the ball joint attached it back on, cleared fault codes. Checked sensors are within tolerance by jacking up the car from the front and back, and watching the voltages change,but yellow headlight symbol still on in the DIS. re-scanned with vagcom. now Error 01539 says headlights Not adjusted(I now know the sensors are working). Anybody know how to adjust the headlights.
TIA. |
All Sorted Now.it turns out I was being a NUMPTY , I recoded it to the wrong setting.
I have now (after a long wait replaced the faulty sensor with (I hope) a working part from Goglawrie's scrapper. The DIS light still remains on. Does that have to be re-set using VCDS or should it be self re-setting? (which would mean that the replacement is duff too!)
Most faults stay until cleared so, without knowing the specifics of that area, chances are you will need to clear it with software.
That's why in many (non-critical) cases the first thing you do is clear the fault and wait to see if/when it reappears.
hi the headlights sensors were working on the car before i scraped it even the bracket was broken so i think need to clear fault codes
Thanks for that. I am sure it will clear the next time I get to scan and clear it.
Vag-Com available in the Glasgow area for £50.00
. Nite Blue 3.0L SE Quattro |
Special offer... £49.95, have 2 scans get 1 half-price (sure that'll appeal to the 'Northern' contingent).. Could possibly even supply a voucher
#30
someone mention Voucher??
Audi S8 2015, Daytona Grey Maserati Granturismo 2008, Metallic Nero Carbonio |
