Old 5th May 2012, 01:03 PM
plankton plankton is offline
Default 1999 D2 4.2 V8 for sale
Audi A8 4.2 40v quattro. Facelift 310bhp model. Silver/black leather (1999 V)
Private plate included (A8 UDH).
Just had cambelt, alternator (ribbed) belt, thermostat and water pump changed (April 2012).
103,000 miles
MOT 28th November 2012
Tax end November 2012
Gearbox oil changed at 60,000 miles.
S8 18" wheels
Electric slide and tilt solar panel sunroof (powers the interior fan when parked in the sun)
Double glazing
Rear(electric) and side blinds
Independent left/right climate control with icy air-con.
Excellent Bose stereo (6 disk cartridge).
Front and rear parking sensors.
Built in Sat-Nav with 2007 disk
Parking sensors front and rear
Front AND rear electric heated seats
Cruise control
Xenon lights
Auto dimming rear view mirror with ambient red interior lighting.
Cheap car tax
"A8" personal plate included
Sump replaced, transmission oil changed.
Pics are from the previous seller - I need to get it cleaned and photographed:
Car is very quick off the mark, and the V8 sounds great. No graunches or odd noises from the gearbox or engine. Tiptronic mode works fine though I tend to just use the auto mode.
The interior of the car is lovely. Leather is in very good order as you can see in the pics. The boot carpet lets the side down a bit, but I don't go in there very often!
There are three warning lights on the dash - this is what the seller told me when I bought it:
1) Empty windscreen washer bottle - must be a stuck float in the bottle I guess. Washer bottle is a pain to get to so I use the "is-there-water-coming-out-of-the-nozzles" test to check it. Still works ok.
2) Brake pads. Uses those thin wires that connect to the pads to indicate wear. Always goes wrong. There is a thread on A8-pages to tell you how to permanently disable this. (Also used to be an ABS fault light which I fixed by replacing the ABS sensor cabling, also from A8 pages. That is now fine). Just due to the age of the wires.
3) Lights. When a brake light needed replacing this came on, after replacing it stayed on, but the lights all work fine.
Rear electric blind works okay, as do all windows. Electric Sunroof operates correctly too.
Elec folding mirrors take an age to fold, but do go eventually (guess 15 seconds).
Heating fan makes a clicking noise when it's been on the screen for a few minutes - select "Auto" and it goes away. I have sourced a D2 Climate Control Flap Positioning Motor for this, though not fitted.
The cooling fan is sometimes noisy, so I have bought a spare D2 Electric Cooling Fan which will come with the car.
One of the displays on the dash is unreadable. One day it worked perfectly - it just shows the date and time (thinks it's May 1999), but not worked other than that.
There is a full size spare wheel in the boot, but the tyre needs replacing on it.
The parking sensors (front and rear) can be a little over enthusiastic, but there is a button on the dash to turn them off when they get annoying!
The maxidot display is tempremental. Not sure what this is called on the Audi, but that's what they're called on Skodas. It's the one that displays mpg / temperature and those three warning messages. It seems to need warming up - sometimes I go in the car and you can barely see the display, though after driving for a few miles, it gets brigher until it's working as it should.
The steering is too heavy on the car - the geometry does need doing on the car.
There is a scratch on the front passenger side door:
I was up ata A8 Parts towards the end of April and I had the air con re-gassed whilst there (won as part of raffle!):
Here's the Service history - I've gathered this from the stamps and invoices. Had to put it in a pic as I couldn't work out the table stuff:
Added to this is the recent work done at Lion Garage (VAG Specialists):
20th April 2012 :
Renewed Timing Belt & Associated Tensioners/Dampers.
Renewed Ribbed Belt & Associated Tensioners/Idlers.
Rewewed Water Pump (Audi part) & Anti Freeze.
Renewed Thermostat & Seal.
Total was: £855.
30mpg is possible on a motorway run (best I've had is 32mpg), though this is not an economical car, so I'm averaging more like low to mid 20's. Heavy right foot will see it in the teens.
I bought the car 10/11/11, and have done just over 2500 miles since then. Am using it as a "weekend car" so it spends most days in my garage. Use my diesel Saab for the long commute to work.
Selling as I'm not earning as much as I used to (Really don't want to sell it after investing £900 on it! Wished I'd realised earlier - could have sold the car for £1500 and still been better off..)
I've listed everything I know about the car - warts and all. Don't see the point of saying a car is superb only for a possible seller to turn up and realise it's not perfect (which it's not going to be at 12 years old and this price!)
£2295 ono
Car can be seen in Hinckley (LE10) .
Kev
1999 4.2 V8
2008 Saab 9-5 TiD Estate 185BHP - long gone. The Merc E250 that replaced it has gone too.
Old 5th May 2012, 03:11 PM
Nollywood's Avatar
Looks pretty clean, and price is fair. Best of luck in the sale.
Old 5th May 2012, 04:46 PM
Webuyanycar value it at £386
I've been offered £300 for the plate, and the tax on it is worth £100. Assuming the scrap value is £200, it must be worth at least £600 as a wreck. There must be people who take these offers (no doubt they'd try to knock more off when they turned up to collect )
Kev
1999 4.2 V8
Old 6th May 2012, 04:13 PM
More pics taken today:
Revised price:
£2195 ono
Kev
1999 4.2 V8
Old 7th May 2012, 10:29 AM
Sold
... to a member of this forum
Kev
1999 4.2 V8
Old 7th May 2012, 11:47 AM
Nollywood's Avatar
That was quick! Any idea what you'll be replacing her with?
