Old 8th May 2012, 06:06 PM
Or maybe when you're doing local driving around town you're both braking more plus turning the wheel more which emphasises the binding brakes issue if it's there and underlying. it will therefore heat up quicker and smell quicker.
I still feel you need to check the calipers a bit more thoroughly. . .
Old 8th May 2012, 06:52 PM
thebluewhale's Avatar
Maybe there is some oil sitting on the block somewhere and due to the slow drive across town then there was a build up in the engine bay, I really don't know.
Does it smell like brakes/clutch or is it a stronger, more acrid smell?
From what you've said, especially as it's on the passenger side, it may be the output flange seal on the gearbox leaking fluid onto the nearside cat.
Could be miles out though but worth a look.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 8th May 2012, 06:55 PM
mannyo mannyo is offline
its the off (drivers) side. I may end up letting a local Blandford garage take a look, the place that did the MOT also do service and other work.
Manny
Past
Old 8th May 2012, 07:01 PM
As I said probably miles out. That'll teach me to read the thread properly. Doh
Old 8th May 2012, 07:04 PM
Reffro Reffro is offline
Another vote for the front driveshaft seal. The brakes do get hot on an A8, but the smell would suggest fluid leak. Mine was leaking for a while and burned off on the Cat leaving little or no evidence, which fooled everyone until we got it up on the ramp and found the leak.
Old 8th May 2012, 10:03 PM
Driveshaft seal will drip on cat and stink, but leave no trace until you look close My D2 had it, smelt like hot oil. Brakes are a very different smell.
Old 9th May 2012, 11:19 AM
Would I be able to see signs of a leak without getting the car up on ramps.
Manny
Past
Old 10th May 2012, 06:55 PM
I don't think you can as it's above the cats (somewhere) at the back of the box (?).
If it is the seal the smell will get worse to a point where you think the car is trying to kill you .
It's a very distinctive smell, not like brakes or clutch.
