Old 9th May 2012, 05:11 PM
47p2's Avatar
47p2 47p2 is offline
Default Time for an oil change
So the A8 was out and about today and when I returned home I decided to do an oil change. Well whoever tightened the sump plug last time must have used the old washer and hiked the plug up as tight as he could. I had to use a 2' breaker bar to remove it
In the air and oil draining
Not a lot of room for a LWB up here...The guys at the Mini-Meet will remember the rope trick
and the rear
I'll let it drain for a while yet before stitching it all back together
Nite Blue 3.0L SE Quattro
