Old 9th May 2012, 09:02 PM
Would a 'tool' gag be inappropriate at this time?
Old 9th May 2012, 09:20 PM
roberto's Avatar
roberto roberto is offline
absolutely its a yes from me
Old 9th May 2012, 09:22 PM
go for it Richard - im sure there are some interesting words like Rubber, flange and oiled that you can get in there . . . .
Old 8th July 2012, 08:53 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Another quick update. My rear caliper was rebuilt and has since been working perfectly. No brake binding or dragging and the PB works perfectly every time.
This I'm, sure will save people a fortune! Wish I'd have known this before I bought a new caliper for the other side
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 8th August 2012, 08:51 AM
A8Jas A8Jas is offline
Default Me next...
Glad I read this thread, my warning light has come on for the parking brake, last week it didn't cycle properly and now the error - although it still seems to work OK. I know the rear pads are 80% worn but I don't know if this affects it or not?
Will run it into Audi next week but I bet they say "new caliper @££££££ please" so if it is just a sticky piston I will look at doing the seal change. Otherwise maybe it just needs a good clean up? Haven't put 50k on it yet but I guess mileage has nothing to do with number of brake activations...
Any suggestions welcome...
Old 1st September 2012, 05:37 PM
manca manca is offline
Hi all
I have the parking brake malfunction warning too (and a problem with my MMI screen but thats for another day!). Might the seals be the problem? Presumably I can order them through a main dealer?
Not a car techhie myself so would need to hand the old girl over to someone to do whatever needs doing. Is it reasonably straightforward or should I be looking for an Audi specialist (and if so any recommendations in the London/Surrey area).
Grateful for any advice.
Thanks Adam
Old 1st September 2012, 06:40 PM
47p2's Avatar
47p2 47p2 is offline
Are you sure it isn't just a broken sensor wire on the front wheel which is a common problem
Nite Blue 3.0L SE Quattro
Old 1st September 2012, 06:44 PM
You do get a different warning for the EPB if it fails, kind of like the brake wear warning, but with a lightning strike through it.
Have you checked the contacts for corrosion?
Old 1st September 2012, 08:13 PM
Thanks both for taking the time to reply.
I haven't checked anything, wouldn't know what I'm doing tbh.
I have a P symbol on the dash with a diagonal line through it and two 'lightening' arrows either side, one top left and the other bottom right.
My wife described the situation to her cousins other half who works for Audi and he suggested a new rear caliper and £500.
I thought Google would be my friend and here I am....
Old 1st September 2012, 08:20 PM
47p2's Avatar
Is your wife's cousin on commission?
Firstly you need to find out if it is the front or back brakes causing the problem. As I posted earlier the front sensor wires can break and cause the light to show on the dashboard.
If any of the pads are low it will show a light on the dashboard, you need to have them checked and the sensor wires checked.
