Thanks Sloss, great info. So I'm thinking to just do the DRLs as the sidelights are rarely used, are there any plug n play 1156 LEDs with the resistors in place?
The brightest I have seen without are 450-480 lumens. If you can be bothered, you can swap the sidelight and DRL pins round in the headlamp connector and recode for LED DRL, then the DRL is used for sidelight at reduced brightness and dims when indicating. |
I've had a quick scan on eBay but there's a minefield of ones out there so any pointers for some nice bright ones that don't require modding or re-coding much appreciated.. ![]() |
