Old 10th May 2012, 11:21 AM
47p2's Avatar
47p2 47p2 is offline
Default DPF...Can I
remove it from the ECU using Vagcom?
Reason being I have been reading about low ash oil required for cars fitted with DPF, I've also been reading that low ash 0W-30 oils can cause premature cam wear. Personally I am not keen on 0W-30 oils as I feel they are just too thin and don't provide enough protection, so I would like to start using 5W-40 505.01 spec oil instead. So now I would like to code out the DPF and remove the filter.
Nite Blue 3.0L SE Quattro
Old 10th May 2012, 11:50 AM
Think you need an ECU re-code for that....
Old 10th May 2012, 12:05 PM
Reflash needed for removal. You need to do both at the same time physical removal and software. A8 Doc and mkoneman should be able to do software side. Probably best to do together with remap.
There is nothing wrong with 0W-30 oil for everyday use. Cam wear was a problem with V6 2.5TDI engines. This was combination of design, higher then now sulphur content in diesel, incorrect oil usage and long service intervals. Using long life service and doing little miles in short distances causes oil dilution with diesel over time. If you change it yearly there should be no problems. And 3.0TDI(as does later 2.5) uses roller rocker arms so no cam wear issue. 0W-30 PD oils have high pressure additives which ensure there is no metal to metal contact and reduced wear on components.
Old 10th May 2012, 06:58 PM
47p2's Avatar
Thanks for the replies, I'll need to investigate further.
Just out of curiosity has anyone used 505.01 spec oil in a DPF engine?
Old 10th May 2012, 08:14 PM
I think Ainer and Nollywood should open up an Audi specialist, I would use them. They know their sheeeet.
Old 10th May 2012, 08:25 PM
mannyo mannyo is offline
I believe 507.01 spec oil is required for a DPF equipped engine regardless of service intervals.
Manny
Past
Old 13th May 2012, 02:32 PM
A8 Doc A8 Doc is offline
DPF removal requires complete removal of the DPF in the exhaust first. Then the ecu needs reflashing to remove the regeneration tables as well as various fault codes.
Happy to help though
Old 13th May 2012, 02:34 PM
sarg sarg is offline
I'm confused.
I thought that the removal of DPFs, or any other original emissions equipment, would result in a MOT failure from this year onwards, so how does this work?
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 13th May 2012, 04:25 PM
I'm confused.
Only applies to Petrol engines, diesel will still only need to pass a smoke test and only if it fails will the cause be investigated. Even with the new lower smoke limits for newer cars, it should pass the smoke test without a DPF.
Manny
Past
Old 13th May 2012, 07:13 PM
Judging from the amount of soot routinely being blown out by diesel powered motors, the smoke test limit must be pretty relaxed. There seems to more black smoke from some cars than a marine Deltic running in the "oil throwever" range. Fortunately (or unfortunately??) there doesnt seem to be a similar propensity for exhaust funnel fires. .
