Old 13th May 2012, 09:23 PM
B@fink B@fink is offline
tinkering with elastictrickery fills me with dread *shudder* thats why I had someone play with such things. Moving ecu's and all those wires......that would give me sleepless nights! probably best seeing if you can find a replacement rather than discombobulating and attempting an internet solder repair on what is frankly a vital bit of kit that effectively makes the car drive itself! I distrust anything involving electronic repairs!
Old 14th May 2012, 06:35 AM
Each to their own. I'm totally happy messing with that.
Now, taking off a cylinder head is NOT my cup of tea at all....
Old 14th May 2012, 08:28 AM
+1
Been there, done that
I am pretty much happy mess with everything. Also done electrical side on ABS pump which many would be afraid to touch once on C4 A6. Or taking airbags off
Old 14th May 2012, 03:58 PM
cylinder heads, now thats entirely more like it. More than happy to do those! can't beat a nice bit of tinkering with an engine's oily gubbins!
Old 14th May 2012, 08:27 PM
Been reading this with interest as i thought mine was a bit hit and miss until yesterday on whether it would work or not.
I think I've realised I've been trying to activate cruise incorrectly for the S8 based on what I've always done with the 2004 A6 we have! I usually flick the switch left to turn cruise on and then just hold it left to increase speed at the same time so I don't get a drop in road speed while it has a think.
It seems the S8 doesn't/won't activate like this, despite the stalk looking identical - if I use the push 'set' button on the end of the stalk having switched on cruise then it was reliably cutting in and I could then use the slider to increase speed, give or take the occasional cut out from the system.
Very rare I use cruise round these parts, but being on the M25 at 6am with lots of average speed checks and a couple of nice tunnels to run through needed a bit of self imposed restraint!!
Adrian
Old 14th May 2012, 09:06 PM
TBH I leave mine in the "on" position all the time, there's no reason I can think of to do otherwise.
But yes, push on the end to set a speed (or slow down if already set).
And flick slider outwards to resume or increase.
It's a rather odd setup compared to all the others I've met over the years, no symmetry to increase/decrease speed.
Anyway, I'm beginning to think the problem with mine must be the control box....
Old 14th May 2012, 09:44 PM
Night Train's Avatar
Odd how it always seems to be capacitors, had to replace 3 in my Pajero (Shogun) ECU, then from dead to running perfectly
with that, the goo drained out of them with the heat cycles & upset the pcb & legs, so had to be a little creative with the dremel, tinned copper wire & some good old fashioned leaded solder.... the ROHS compliant stuff is rubbish, just can't take the heat cycles & crack (which is why the nvidia GRAPHICS chipsets on laptops give up- so never let your teenagers use them on their beds - blocking the ventilation as well as clogging the heatsinks)
Not afraid to get oily & dirty, or burn my fingers with the Weller, Pace, or gas iron...
Curious to see how you get on with it HP
Other vehicles
Oh Yes....... The '98 PF S8!
