Old 13th May 2012, 04:22 PM
Default Automatically setting clock
Reading through the owners manual there is mention that the clock can automatically set the time based on a radio signal. Is this a standard thing across the range, or is it one of those things that only work in certain countries? I certainly have never seen the little aerial picture to the left of the clock.
Old 13th May 2012, 04:32 PM
No, I've never got that to work either
Old 13th May 2012, 06:17 PM
I understand the 'radio' signal is only available in Germany. Also, UK cars are not equipped with antenna module.
Old 14th May 2012, 01:45 PM
christhompson's Avatar
Doesn't work for me either. I assumed it was because a previous owner replaced the single DIN radio with a flip screen satnav and the clock got lost on the way. The car has been on the German border and up by the UK time provider so I guess its not that.
Old 14th May 2012, 02:42 PM
My PF D3 did it when I first got it, then stopped after the MMI update. Not sure if there's a hidden setting to turn it back on, but my FL doesn't have it either.
