Old 13th May 2009, 07:18 PM
I have just picked up a set of C5 RS6 (2004) rear calipers and disks. Will be fitting them this weekend. Update to follow.
Old 13th May 2009, 07:32 PM
thebluewhale's Avatar
Check the bolt sizes that bolt the caliper frame on the hub. If they're 10mm you'll have to get your drill out as the standard rear bolts are 8mm.
It looks like you'll beat me to the 'How to'. The first time I tried to fit the rear calipers I failed miserably!
Old 24th May 2009, 03:20 PM
Mike,
Did you fit the RS6 calipers and discs in the end?
Steve
Old 24th May 2009, 04:29 PM
Steve,
It did not go well!
While the carriers bolted directly to the hub, the hand brake pull is longitudinal whereas the S8 hand brake cable is transverse so I have ordered up some longer handbrake cables. I was also not able to get the disk on as it is too big (335mm) for the carrier by a few millimetres so I will have to have the disk machined down to fit.
So no. RS6 C5 rear brake callipers are not a direct replacement. I will get the handbrake cable to fit before I reduce the size of the disk just in case its not possible. The disks are almost new as are the Ferrodo pads.
More to follow.
