Old 6th June 2012, 09:08 PM
Fixed camera indoors (after batting midges off). How about these?
Name:	Black box in battery compt(2).jpg
ID:	3818   Click image for larger version
Name:	Black box in battery compt(3).jpg
Old 6th June 2012, 09:20 PM
47p2's Avatar
47p2 47p2 is offline
Looks like 4DO 907 133 A
Windscreen heater control unit for Audi A8, S8
Nite Blue 3.0L SE Quattro
Old 6th June 2012, 09:23 PM
That's the one you need to take out and run the wires that I stripped back a chunk for you to re-fit a screen into the other car.
Bizarre, I posted that link (in "English", not translated) a few minutes ago but it disappeared :
http://www.yas-group.com/epages/6161...19/Products/30
Old 7th June 2012, 07:03 AM
Default these bits
[IMG][url]http://i1066.photobucket.com/albums/u409/goglawrie3027/IMAG0126.jpg[/url[/IMG]] and
[IMG]http://i1066.photobucket.com/albums/...7/IMAG0125.jpg[/IMG]i hope this works
Old 7th June 2012, 07:34 AM
Those look like the terminal blocks + attached wires for the screen heater control unit. What happened to the control unit? Is it a replacement you are after?
Old 7th June 2012, 08:56 AM
Default heated front screen
im trying to retrofit screen to my car and need to understand all wires etc if i can see yours that could help thanks
Old 7th June 2012, 11:13 AM
Here's a picture with the terminal cover off. The wires are (from the left):
1. yellow/Blk (going to separate push connector).
2. Red (to clamp connection).
3. Brown (to clamp connection).
4. Brown/Blk (to clamp connection).
5. red / Blk (to clamp connection).
Does this help?
I have looked on the Mitchell's wiring diagram for 2001 A8, but there is no mention of the front heated screen on the diagramme for "Defoggers" on page 8.
ID:	3820   Click image for larger version
