Old 15th June 2012, 06:55 PM
I put the Pagids on my PF D3 and wasn't that impressed TBH. They worked, but just no real feel from them.
VCDS will tell you the amount left on the rears as there's no sensor as such, it uses the travel in the EPB for that. Inside pads usually wear faster than outside as that's the bit that gets pressed into the disc first. When the warning first appears you've got 1-2k left at least, so no specific rush either.
