Old 16th June 2012, 09:36 AM
If it is expensive, I would put the money towards having the filters taken out of their boxes and trashed and then ECU reflashed sans DPF.
I had mine taken out at 175,000miles due to blockage and it is much better without. You have two and it costs about £2400 to replace them!
Old 16th June 2012, 12:09 PM
Default What a great forum!
Ah, okay so looks like I need a G524 then Shame it looks a bit of a pain to get too "on gearbox rear" but I will give it a go!
I was working form what I could see in this doc http://www.volkspage.net/technik/ssp/ssp/SSP_365.pdf but the info posted above looks more specific to my car so many thanks 47p2
David, I will send you an email shortly and would be very appreciative if you could source the part for me Will try and get it fitted ASAP and post back how I get on.
Thanks to all
Old 16th June 2012, 02:50 PM
47p2's Avatar
47p2 47p2 is offline
Bank 2 looks to be sensor G505, double check numbers before ordering!!!
Also see attachment for sensor G450 which is the exhaust pressure sensor
ID:	3876   Click image for larger version
Name:	Exhaust pressure sensor G450.png
Nite Blue 3.0L SE Quattro
Tags
4.2tdi, dpf, pressure, sensor
