Well guys, following on from the battery issue I had, it now seems the car thinks I've got a permanently attached trailer/caravan!
This means the car is currently sat in towing mode, without the ability to turn it off in the mmi ![]() Anyone else experienced this? |
Does your car have towbar fitted? Could be a short there.
Does it have the socket for a towbar electrics fitted?
If so it could be water that is causing a short Edit You just beat me there Richard....
. Nite Blue 3.0L SE Quattro |
It does have a detachable towbar. I pulled the socket down today, we've had a lot of water with the rain here, but couldn't spot any signs of ingression. I guess I'll have to get a hair dryer on it or something.
Does anyone know what fuse controls the electrics going to the socket? If I can pull that, I can then quickly identify if that's the issue |
Spray plenty WD40 into it and it should help
A big thanks to PsYcHe who yesterday coded out the towing control ECU for me, and adjusted the parking sensor, and self levelling system to think it hasn't got a towing control unit.
The car is now back on track, but I obviously have an issue with the towing control ECU on the car, but have no idea where it is!!!! Anyone got a clue? Thanks ![]() |
You'll find it lurking underneath the battery - remove the battery and you'll see a couple of Torx screws holding a black box to the panel underneath. It will be printed with Westfalia logos.
2003 D3 A8 4.2 Atlas Grey - Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid After: LPG, AMI with HDD Pending: DVB-T Tuner & fixing niggles |
Here is the retrofit instructions from Westfalia, who are the OEM for the towing system..... hope it helps
![]() http://www.westfalia-automotive.de/f...7391101-02.pdf |
Under the battery... Hmm... Wonder if it's just a loose connection under there.
or water, that's where I was getting water ingress from one of the drains - a fat blue pipe just in front of the battery compartment going to the wheel arch...
