Old 15th June 2012, 12:48 PM
Default Cannot calculate a route - now I can!
Some weirdness with my RNS-C that I think was triggered around swapping CD's (2007 Final Edition non-DX from England to Scotland).
It just refused to calculate a route, though otherwise all seemed fine.
I swapped around, even went back to my 2003 CD, no joy!
So I pulled the relevant fuse in the boot, waited, and put it back. No change.
The map display was showing me in the correct place and when I put a nearby destination in showed that too, but wouldn't connect them.
Then I thought - the car's on the drive and hasn't been moved through all this .........
So I started it up and drove backwards and forwards a couple of times - only about the cars length, I didn't go onto the road. And it started working with no intervention.
I don't totally understand the logic, but presumably it hadn't "attached" me to a road (or lost the connection while swapping CD's) but didn't complain or come up with an "off-road condition". Just moving backwards and forwards a few feet obviously made it think I was on the adjacent road and kick into life.
Very weird, but worth knowing if anyone has a similar strange experience.
Old 18th June 2012, 11:57 AM
Condor Condor is offline
I've had a recent odd glitch with my BMW X5 satnav (2005 4.8is) which sounds remarkably similar and have read of a few similar occurences amongst factory fitted satnavs of a similar vintage over the past few weeks in BMW, Audi and other marques. Wondering if it has anything to do with satellite changes as they fall out the sky and are replaced or not, as the US is apparently not replacing them at the same pace as before due to financial constraints........some of the older units have software presets to the original satellites and appear to lose track for a while, later rectifying themselves as they lock on. Haven't driven the S8 for a while as have been using the X5', but planning to use the 8 as soon as I can do a driveway shuffle and get the 8 out and the X packed behind her, will check satnav then, its an RNS-D.
