Old 28th June 2012, 04:38 PM
Good to hear
Did they measure how much fluid came out? It's always an interesting piece of info
Mine took 8 litres when it was re-filled after a filter change, but might be that the box is slightly different seeing as mine's a late one?
Old 28th June 2012, 04:50 PM
I didn't ask and they didn't volunteer the info.
After my "test drive" I had to visit someone literally over the road from the garage and as they were still open I popped back in to say how pleased I was.
The owner and the techie who did most of the work said that what came out was pretty black and the filter was filthy. They suggested doing it again in maybe 50,000 miles more if I was keeping the car.
I said I'd see how it behaves, but probably do it again at the next major service (or earlier) as a precaution and because there would still be a fair proportion of crud inside even now as only about 2/3rds of the old fluid was removed. They said if I did it soon the filter would probably not need replacing and that and the associated gasket were about as much as the fluid so a fair saving.
The owner did also say that the fluid for the latest (8-speed?) gearboxes was twice the price!
Old 3rd July 2012, 12:01 PM
Hmmm..................................
Did a fair bit of driving over last weekend and whilst generally MUCH better it did still have the odd "moment".
One in particular was noticeable; I was doing at most 20mph turning right around a very large (sized for artics) empty roundabout on a backwater road (Industrial estate shortcut on Sunday lunchtime, so deserted).
As I started to turn left to exit it juddered a few times as if changing it's mind about what gear (2nd or 3rd I'd guess) then settled down OK.
I was driving VERY sedately as I had a frail 93-year-old passenger in the back!
The centre (Torsen) diff has had its oil replaced, but the rear one hasn't (drain plug in too tight) so not sure if that might be relevant.
Just wondering if the gearbox ECU might be suspect; if so are they swappable or do they need recoding?
I do know (think I mentioned this before) that my car has had a "chip" replaced ("Superchips" early in life, before me) to remove the 250kph limit and allegedly adjust the midrange gearchange points - would that be in the gearbox or engine ECU. It was only 1 chip as I have the original.
As I have never, and will never, exceed 250k in this car I'm very happy to revert to "S8 standard".
Further thoughts anyone?
Also can anyone outline or explain how the gearbox and ECU interact, i.e. what measures and decides what and how changes are controlled, as I believe there are some electronics inside the box itself - or are they just sensors and actuators?
Old 3rd July 2012, 12:13 PM
sarg sarg is offline
did the judder feel anything like a clutch slipping?
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 3rd July 2012, 12:17 PM
Not really and didn't notice revs increasing (not that you do ).
More like "hunting" between gears.
Gearbox itself is totally dumb - No electronics in there. All the intelligence is in the Gearbox ECU. It basically just opens and closes vales in the gearbox to more oil around and shift things.
The ECU's arent coded, and can be swapped straight over.
Speed limit restriction will be on the engine ECU.
Adjusting the shift points is down to the Gearbox ECU
A little hiccup like this doesnt sound too scary. You can catch most Autos out if you try hard enough. I'd be more concerned if it was thumping about driving in a straight line at a fairly constant speed....
Old 3rd July 2012, 12:22 PM
It's fine at constant speed.
So far....................
Old 3rd July 2012, 01:49 PM
I'm a long way from doing that, but with "used" prices at £100 to £150 it may be worth trying some time. It looks to be a relatively easy swap as it's on top in the ECU box.
There seem to be lots of identical-looking gearbox ECU's with part numbers starting 4D0 927 156 but various suffix letters.
Presumably the suffix is critical, anyone know what my late PF S8 needs, or do I need to "open the box" to check?
Old 7th October 2012, 03:38 PM
Well the thread I started separately on this subject has revealed the answer.
It seems I (most probably) have an ECX version 5HP24A gearbox and I definitely have a 4D0 927 156 BL TCU (confirmed by VCDS).
Member ainarssems said the BL is for use with ESP (which I obviously have) and there's a BM version for non-ESP.
Since having the gearbox fluid/filter change I've had no more thumps, just the odd "twitch" and since the gearbox coding change from 00101 to 00111 (which I think turns off DSP) it's been even smoother though I have had one "twitch" today.
This was going up a steepish hill from a junction, fairly straight, probably in 3rd heading for 4th and again felt as if it couldn't decide what gear to use. Following that I tried to recreate it in "tip" mode and couldn't - it wouldn't misbehave when in any gear even with a heavy right foot and forced changes up were all fine.
The only thing I haven't tried yet is to see whether having ESP on or off changes anything when in Drive. Given that there are ESP and non-ESP versions of the TCU it's just one more thing to try. Also most earlier occurences have been in situations where ESP might just be "considering" doing something.
Given that I've been told the middle gear changes have been "tweaked" (though I have no details of how) I'm still leaning towards trying a replacement TCU when other options are exhausted.
Any and all suggestions welcome on what to check and how.
