Old 8th July 2012, 06:37 PM
Default Now this is a cheap Maserati Quattroporté
god these are getting tempting - low miles (28,000) and under £20k uhhhhh
http://www.pistonheads.co.uk/sales/4022178.htm
Old 8th July 2012, 06:48 PM
47p2's Avatar
47p2 47p2 is offline
They are nice but I think I would give that one a miss since it's been his wife's daily drive the past 4 years and she managed to burn the clutch out
Nite Blue 3.0L SE Quattro
Old 8th July 2012, 07:26 PM
Haha does that scare you? seems pretty good to me for the mileage/price!!
I think it'd be less painful to spend £20k getting someone to remove your fingernails with a pair of pliers than to own one of these as a daily!!
The robot manual is a fecking nightmare - I believe about 40k miles is as good as the clutch life gets in these. They did start to produce a 'proper' automatic and if you had to have one, that'd be the only option worth considering.
I knew a guy who works in EMC testing (actually he owns the business) who used to run one of these and he decided to do a regulatory test on it, just out of interest.......£10k bill later and most of the warning lights were out and the car did actually run again! That's a regulatory test, so think about that one for a minute when you ponder what other corners they've cut.....even a Renault Scenic will survive this type of testing with nothing more than the odd flashing light that goes out when the test stops.
Old 9th July 2012, 12:55 PM
sloss's Avatar
sloss sloss is offline
Well, if it's just had a new clutch then you have 40k carefree miles ahead.....
What's a 'semi-auto' anyway?
Old 9th July 2012, 01:31 PM
graynada graynada is offline
Usually a gear lever but no clutch pedal. You just move the gear lever and the declutching/clutching is taken care of automatically.
Old 9th July 2012, 02:05 PM
sloss's Avatar
I had a car many, many years ago with a system like that - it was called Manumatic. May have been on a Wolsley or Riley I had then.
It had a button on top of the gear lever that when pressed put the clutch out to enable a gear change.
The clutch was centrifugal so no need for a pedal.
It even revved up on down changes to match engine speed to wheels
Old 9th July 2012, 03:38 PM
the gearbox in this thing is basically similar to the BMW SMG box in that it's effectively a manual, because it has a clutch, but the operation of the clutch is entirely controlled by computer. So if you're a muppet driving it it'll sit there burning the clutch out as long as you're prepared to sit there doing the 'wrong thing' with it, until it goes pop.
From a licence point of view it's more automatic than manual (hence 'semi') as there's no 3rd pedal so you can drive it on an auto only licence.
Old 9th July 2012, 07:36 PM
Lol sounds like some kind of lady's dodgy sex doll!!
