Old 14th July 2012, 11:10 AM
Default Step 7, trim screws
7. Undo the two remaining screws that hold the exterior plastic trim onto the metal mounting plate. The 3rd screw outside near the pivot was removed in step 1.
These are typical coarse-thread self-tapping screws into plastic so do not overtighten on reassembly.
You can see the main electrical connector (for folding and heating) mounted on the unit and the 60cm cable for the secondary (memory) wiring.
