Old 15th July 2012, 10:54 PM
And after several trips with and without front seat passengers large and small it still is.
No seatbelt or airbag warnings of any sort.
Before I go and remove my "choc-bloc" temporary lash-up and properly crimp the short-circuit into place has anyone with more knowledge any thoughts?
No comments on the airbag warning, but you have mentioned seatbelt warning a couple of times now... Never seen a seatlbelt fault, not even sure they were wired up on Preface ? On Facelift there are ignitors on the seatbelts to pre tension, but no sensors that I'm aware of.... Later Audis do, and by default do that annoying binging noise when you drive with no belt on...
