Old 23rd June 2012, 07:58 PM
s2_bo s2_bo is offline
Default Correct spark plugs for 8s on LPG
What plugs are you LPG guys using in your 8s running LPG?
I have been looking around online and there is so many mixed vies im now just
Would like to change mine when i next service so any hints on correct plug appreciated.
Thanks in advance.
Bo
Old 17th July 2012, 06:54 PM
funkmiester funkmiester is offline
Default lpg plugs
Been a while since I have been on, apologies!
My 2002 s8 has 170K on it and was running Bosch super 4's when I bought it at 120K. It was converted at 60K so has over 110K on LPG. I switched to iridium at my second service (130K), LPG specials and they resulted in lumpy running after only about 15K miles (diagnostic check showed misfire, swapped plugs and coils, turned out to be plugs)
Put them in the bin and went back to bosch, never missed a beat since.
I can look out the exact reference if you are still looking. I don't make a habit of dissing products online but those iridium ones were expensive rubbish, In fact I was away camping at the time and put the old bosch ones back in and it solved the problem, then replaced them with new bosch when I got home.
