Old 29th July 2012, 01:10 PM
aka_dk aka_dk is offline
Default C6 RS 6 20" wheels fit on an D3 A8 ?
hi chaps
wondering if you can advise
will a set of OEM C6 RS 6 20" wheels fit to an A8 ? they are 9.5J ET36
Will they need spacers ?
Thanks
David
Old 29th July 2012, 03:14 PM
Hi mate
I think it'll be questionable to be honest
The specs of the 20s on my S8 are 8.5Jx20 ET45
By my reckoning you would have 4mm less clearance on the inside, which shouldn't be an issue. But they're going to stick out an extra 22mm!
You'd probably get away with it on the back but I don't know anyone running fronts that wide.
The 9" wheels from the D3 do fit the D2, but with 7mm less inside clearance and they only stick out 5mm to the outside.
That's using this wheel spec calculator http://www.1010tires.com/WheelOffsetCalculator.asp
Adrian
