View Poll Results: Which rear callipers and disks do you use?
Standard callipers with standard disks 7 46.67%
Standard callipers with EBC disks 1 6.67%
Standard callipers with Black Diamond disks 0 0%
Standard callipers with other disks (post below) 3 20.00%
RS4 rears with standard disks 1 6.67%
RS4 rears with afterarket disks (post below) 0 0%
RS6 rears with standard disks 1 6.67%
RS6 Rears with aftermarket disks (post below) 0 0%
Other combinations (post below) 0 0%
I have a parachute 2 13.33%
Voters: 15. You may not vote on this poll
Old 4th August 2012, 10:36 PM
RallyQuattro RallyQuattro is offline
PF is a no... not without swapping them for a FL, and not an early FL either as they had the same hubs...
What is an FL ?
And do you know that RS6 rear will fit this FL ?
Old 4th August 2012, 10:42 PM
Originally Posted by thebluewhale View Post
Right,
As you've already found out the offsets for the RS/S6 setup are a bit out. Mike (Conan) tried to fit S6 rears to his and gave up. I think the front offset for RS6 discs are out as well. You may need RS/S 4 fronts.
The easiest rear brake upgrade is the B7 (I think) RS4 discs and calipers. It's fairly straight forward as you only need to drill out the hubs an extra 2mm to mount the calipers and fit the handbrake cables from an A8L.
Your car is a '97 so you have the steel hubs. I have a set of steel hubs pre drilled ready for the RS4 calipers. They're a bit tatty now but perfectly useable if you're interested.
Good luck with it
But now i have bought RS6 brakes...
And RS4 i think is only 324mm right?
And who is it in the Poll above that have fit RS6 rear brakes?
Old 4th August 2012, 10:49 PM
Originally Posted by RallyQuattro View Post
What is an FL ?
FL = Facelift model
PF = Pre Facelift model
I think it was Conan The Librarian
Old 5th August 2012, 07:30 AM
And FL He means 2003-2006 right?
But have anyone mounted RS6 rear brakes on an 2003-2006 A8/S8 ?
Old 5th August 2012, 08:08 AM
No not quite - he was talking about the D2 I think not the D3 shape -
The D2 Original Shape A8/S8 - (called 4D by Audi)
Pre Facelift - 1994 to Sept 1999
Facelift - Sept 1999 to Nov 2002
D3 Next Shape A8/S8 (Called 4E by Audi)
Pre Facelift - Nov 2002 to 2005
Facelift - 2005 - sept 2007
Further Facelift Sept 2007 to 2010
D4 Current Shape A8/S8 (Called 4H by Audi)
2010 to now
If your S8 is a 97 then it is a D2 PF
Old 5th August 2012, 08:55 AM
But i don't think that RS6 rear brakes will fit D2 facelift either, but maybe it fits D3
But D3 have electric handbrake so maybe no one have tested to uppgrade the rear brakes on that one.
Owns at the moment:
S8-97 biturbo = RS8 My new trackday car
A8-94, A8-96, A6 1.8tq -2004
2 Urquattro 20v-90 one red, one blue,
and one old Urquattro ex rallycar,
and some other cars..
Old 5th August 2012, 10:44 AM
Amanda Amanda is offline
I have the c6 brake upgrade on my c5 ( ft and rear)and yes the c6 rear brakes have the electronic handbrake attached but I have movit calipers with audi discs and pads with a bracket made to attach the handbrake. Martin at unit 20 fitted mine but I don't think he is using that now as he is doing a Loba version.
Old 5th August 2012, 05:57 PM
C5 and C6
Are you talking about an A6 with RS6 brakes or what?
Owns at the moment:
Old 5th August 2012, 06:11 PM
Where can I find used rear brake calipers and discs from RS4 B7 ?
Owns at the moment:
Old 5th August 2012, 08:02 PM
C5 and C6
No an rs6 with 2 types of brakes
