Nice, I saw a kit like this for the C5 when I had the RS6....
Its not so bad if you drive a D2 all the time, you get used to having to use the indicators normally. My problem switching into and out of D2's is the wifes car does have convenience indicators and I was forere doing silly single indicates on motorway lane changes when I got back in the D2.... lol A nice retofit of a modern feature... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
OK, the kit has arrived.
As seen on diagram, installation should be very straightforward...
I'd rather drive on left |
OK, installed the unit.
The most logical place to connect the unit is to get required wires from steering wheel harness. That involves removing cover under the steering wheel. There's plenty of space to attach the unit with double sided 3M VHB tape or to hide the unit under noise insulation. Although unit will be connected to steering wheel harness I'll be physically installing the unit on passenger side of the car above the glove box since there are OEM relay slots there. Snaking wire to other side of the car is not covered in this writeup as I only wanted to document what we connect with what to make the unit functional in A8 D2, so this is 'reduced' writeup, skipping some obvious steps. It has worked on my car (February 2002) and I can't guarantee it'll work on your car. Please check wiring diagrams. The unit comes with 5 wires: 1. brown -- (15) ground 2. black/white -- (31) ignition controlled +12V 3. white/green -- (49a) blinker common 4. white - (49L) blinker left 5. green - (49R) blinker right Ground and ignition are easy to find. This write up will concentrate on putting our hands on last 3 wires without having to disassemble steering column. 1. Remove cover under steering wheel: 2. Steering wheel harness is secured with U-shape metal bracket: 3. Remove bracket and remove adhesive fabric tape: 4. Put aside the 3 wires: 1. black/white/green - (49a) blinker common 2. black/white - (49L) blinker left 3. black/green - (49R) blinker right Here they are: Two things: A). Make sure you choose 1 sq.mm wires. There are thinner wires of the same color combinations in the harness, 0.35 sq.mm -- we don't need those. They are too thin. B). Black/white means black color wire with white stripe. It doesn't mean white wire with black stripe -- be careful. 5. (49a) blinker common. Solder black/white/green wire from steering wheel harness with white/green wire of the unit: 6. (49L) blinker left. Solder black/white wire from steering wheel harness with white wire of the unit: 7. (49R) blinker right. Solder black/green wire from steering wheel harness with green wire of the unit: 8. (31) ignition controlled +12V. This obviously exist in steering wheel harness, but I took it from fuse box. It is rightmost 15A fuse in yellow bar. Behind the fuse you'll find thick black/blue wire. This is our ignition. Connect it with black/white wire of the unit. Make sure length of wire allows you to hide the unit where you want it to be. Extend wire if needed. 9. (15) ground. Interestingly, there is bunch of brown ground wires in steering wheel harness, but they are all too thin for us: 0.35 sq.mm. We need 1 sq.mm ground. So I organised my own ground by attaching to fuse box fox. That bolt is welded to chassis of the car. No picture. 10. Insulate and put everything back. I use 3M insulation tape and Certoplast fabric tape. Certopast can be ordered from Kufatec. Hope it helps. If you decide to install this kit in your A8 D2 please don't hesitate to ask questions. P.S. In future, if you won't like functionality of comfort blinkers just remove the unit from supplied electrical connector and this will completely restore factory functionality. Stick unit back into connector again and your comfort blinkers will return.
I'd rather drive on left Last edited by notorious; 7th August 2012 at 10:11 PM. |
