Old 8th August 2012, 05:55 AM
18055/P1647/005703 - Check Coding of ECUs on Powertrain Data Bus
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Coding of Powertrain related Control Modules wrong/incomplete
Possible Solutions
Brake Electronics
Check Powertrain Control Module Coding, especially check the Airbag Control Module Adaptation Channels 050 & 051.
18331/P1923/006435 - Please Check DTC Memory of ECU Number 2
Possible Symptoms
Possible Causes
Fault Code(s) stored in Engine Control Unit 2
Possible Solutions
Check/Fix Fault Code(s) in Engine Control Unit 2
Special Notes
This fault code is a note since the system it is stored in interacts with the Engine Control Unit 2 and due to a fault code there it may not be fully functional.
