Old 8th August 2012, 05:19 PM
gninnam gninnam is offline
Cheers all.
No issues with the engine before the battery change at all.
Only since the new battery went in - before the battery change at tickover and stationary, it purred - now the whole car rocks.
Will have to pay a visit to Limoncello tomorrow (if OK with him) and run another diagnostic again......
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 8th August 2012, 05:45 PM
no probs im in most of the day
Old 8th August 2012, 07:34 PM
Cheers - will aim to be there in the morning, around 11:00 - that OK?
Andy.
Current cars:
BMW i4 M-Sport
Old 8th August 2012, 08:33 PM
no probs, hopefully the problem will be easily apparent when we scan again.
Old 8th August 2012, 09:32 PM
Very strange. I have had the battery out before, and left the car without battery for days, on re-connecting no issues at all, I didnt have to re-adapt any settings.
However, I too have this rocking, or wobbling on idle since last year, but no problem once moving, as proven by 0-60 time at GTI apparently no performance loss, no codes, no missfire detected. Just a very strange idle, I still havent got to the bottom of it.
Old 8th August 2012, 09:54 PM
Before the battery replacement, just idled silky smooth.
More worrying is when I now put the foot down and it feels really hesitant - like a misfire, but before the battery, not issues.....
Gave it a service (new plugs, filters oil etc) only 3 months or so ago so stumped by what it could be now..
Will hopefully find out tomorrow - will let all know
Andy.
Current cars:
BMW i4 M-Sport
Old 8th August 2012, 10:27 PM
RanjS8 RanjS8 is offline
Default Battery Ground Connection
If all was fine before changing battery....then I would swap it out and put in the old one and see what happens....might be worth checking the connections on the battery and the ground connection.....
Try putting a multimeter across the battery to check the voltage also....should be about 13-14 volts when engine running as the alternator should be charging the battery
Old 9th August 2012, 07:37 AM
They kept the old battery so can't do that but will check the battery as you say during charging.
Hope I get it sorted today otherwise I might have to use the Focus......
Andy.
Current cars:
BMW i4 M-Sport
Old 9th August 2012, 05:02 PM
Well - its sorted
Not sure if it was the resetting of the TBP (throttle body position) but after putting on around 50 Miles it is running like a good 'un again
Andy.
Current cars:
BMW i4 M-Sport
Old 9th August 2012, 09:34 PM
Good to hear it was that easy. Resetting throttle body didnt cure mine unfortunately.
