Old 13th August 2012, 01:13 PM
1. If there is too much oil it splash around too much and piston rings do not clear all of it from cylinder walls completely so it ends up in cylinder and from there in exhaust.
2. Second is through engine ventilation system it gets in intake manifold and then pass through engine to exhaust.
It's also no good because overfilling with oil reduces air volume in crankcase. This causes greater variations between peaks and dips in crankcase pressure as its pulsating from pistons going up and down and can lead to blown seals.
Old 13th August 2012, 01:45 PM
Thanks for this explanation.
Second point makes sense for me.
First point I still struggle to fully understand as I thought performance of rings doesn't depend on amount of oil under them.
How sensitive Audi V8 engines are for oil overfill? 4.2 / 3.7 engine normally needs 7.5-8 liters of oil and if I fill 9 liters, is this an immediate disaster? Any horror stories?
Old 13th August 2012, 01:57 PM
47p2's Avatar
47p2 47p2 is offline
I owned a 944 for a couple of years back in my (much) younger days. Took it into the Porsche dealer to have a service and two weeks later I noticed a pool of oil on the garage floor. I checked the oil level and was horrified to notice it was well over the high mark on the dipstick. I called the dealer and explained to the service manager that I had a rear crankshaft oil leak and asked if overfilling it with oil could have caused the problem, to which he replied that overfilling puts lots of extra pressure on engine seals and most certainly did cause it to blow the seal. He wasn't so happy when I told him that they had just serviced it and overfilled it and therefore I was holding them liable for repairing the leak. They did agree to replace the faulty seal and filled it to the correct level once finished
Nite Blue 3.0L SE Quattro
Old 13th August 2012, 04:08 PM
Thanks 47p2, interesting horror story with a good end
Do you remember how much higher was the oil level on dipstick? Was it like two times higher than the distance between max and min?
Old 13th August 2012, 04:16 PM
47p2's Avatar
From memory it was around 1" above the high mark
Old 13th August 2012, 04:27 PM
1 inch above high mark is a lot
Old 13th August 2012, 04:35 PM
47p2's Avatar
Which is why it caused the seal to rupture.
The modern method of checking the oil level is to have the engine hot and switch it off and leave for 5 minutes, then check the level. I find this completely inaccurate and always check it when cold, I remove the dipstick and let the dip-tube drain clear, usually around 15 minutes to clear all the residue and then insert the dipstick and take a reading, this gives a far more accurate reading without any pick-up of oil from the tube marring the accuracy. I always make sure the level on the dipstick is about 2mm below the top mark when cold, this allows for any expansion without going over the mark
