Old 15th September 2012, 10:21 PM
Reffro Reffro is offline
If the TMC was from my old car, it may possibly be faulty. When I bought the car the radio reception was non-existent. The car had a new aerial fitted in place of the phone aerial. I knew Ranj was going to fit the RNS-E, so never went too much into the details of what happened when I got the car, therefore he was unaware that there may be a problem with it.
Old 16th September 2012, 12:21 AM
RanjS8 RanjS8 is offline
Default tmc module
the tmc module is from a different car.
I found with Reffro's car that the aerial was totally aftermarket and the wiring from the aerial had a connector which was not quite compatible with connector on the back of the rns d....someone had taped the two connectors together hence not a good connection....
I dont think tmc module would cause issue with radio reception to be honest, but it is on my to do list.
Old 16th September 2012, 07:23 AM
I dont mind the fact the TMC does not work for Radio, it would have just been good.
Looking at the guide to install the RNS-E, maybe in the future. Having completed this I now feel that an E install is far simpler in comparison.
Old 16th September 2012, 08:09 AM
Default with rns e
The issue with an rns e install is the getting the unit at the right price as you need one from an a6 so you can trim the sides down, which are normally quite pricey around the 5-600 mark.....unless you can get hold of the fascia off a broken rns e....
I would keep an eye out for a broken rns e from an a6....and then get the cheaper rns e's from an a3 and switch the fascias over.
Managed that and the rest will be a doddle....the annoying element is that you lose the dis instruction on the instrument cluster...otherwise plain sailing once you have done a rns d instal.
