Old 24th September 2012, 01:03 PM
So , I now have a new battery, and after 2 weeks the problem returns
Im again getting the 3 minute warning and warning in the dis
What are my options now, is it only down to alternator ( I would have thought that other warnings would appear if this was at fault )
or
the energy management control unit
anything else could cause this?
Old 24th September 2012, 01:21 PM
I think that may just be the D3... mine does it too
Old 24th September 2012, 01:33 PM
really, it happens on yours as well? its damn annoying, im tempted to get another ecu , but wanted to check if it could be anything else. the fact that it seems to last a few days if i change the battery serial number with vagcom seems to indicate an ecu problem to me.
Old 25th September 2012, 07:36 AM
I found a couple of things last night
1. many references to current drain caused from the phone module
2. and a TSB which seems to point to a current drain from the Radio which doesnt get switched of when it should. resolution is to update to 5570
my car was updated to the latest some time ago when i had the bluetooth fitted, but i think not all the updates were done, only enough to do the phone so this could fit.
I havent got a cd player in the car so will have to remove the ami and replac the cd before i try to update so last night went out ran the car and turned the MMi of to see if it makes a difference
Psyche - is your car defo fully updated ?
Old 25th September 2012, 10:06 AM
My PF D3 wasn't updated to 5570 until not long before I sold it, and I've never left the radio on in my new one, but that has 5570.. will check at some point soon.
Old 25th September 2012, 10:12 AM
mine shows 5570, but that only means the MMi has 5570, it doesnt mean all the components were updated, im pretty sure thinking about it that the amount of time taken during the update wasnt enough to do a full update.
i didnt see a way of turnng the radio off, just shut down the MMi and hoped that would do it , this morning ive given it a run and now switched of the phone and the MMi, i also unticked the "delay" button in the phone settings which keeps the phone on after the mmi has closed.
will see later if its made any difference
Old 25th September 2012, 09:25 PM
Somerandomguy's Avatar
I think there was also a service campaign for the battery ECU, mine had it done early in its life. If you look in the back of your service book, it should be recorded there. Ill double check mine tomorrow to see what the code was.
