Old 25th September 2012, 01:18 AM
Baryonyx's Avatar
Baryonyx Baryonyx is offline
Default D2 A8 - how to rebadge
Morning all,
I've recently acquired the 'A8' and '4.2' badge for my A8 in the post off the orginal seller, Bushido.
I was wondering how best to go about fitting these on a car, as I've never reattached a badge before. What material should I use to attach them? I've had doubled side sticking tape recommended, but the lettering of the badges is quite think and would obviously 'show' if I just taped it to the back of the badges!
Also, is there a means of working out positioning, or is a visual estimate taken from looking at badged A8's coupled with a small spirit level usually enough to provide a satisfactory result?
I also plan to move the Quattro badge back to it's original place, how will I remove this? A hair dryer to loosen it off and then re-attach it by the same means as the other badges?
Chris
Old 25th September 2012, 07:46 AM
I've no idea how to attach the badges, but I have had some success in removing them (I had a 2.8 that had been badged up as an S8 years ago!). You can buy a good adhesive cleaner/solvent made by 3M that works a treat and doesn't mark the paintwork. I'll have a look whan I get home for the brand. Spray liberally with this and carefully insert some fishing line or dental floss behind the badge and work it through the adhesive, keeping the area soaked with plenty of the cleaner/solvent. Patience is required here! Once the badge is off, use more solvent to remove the final traces of the glue and then put some polish/wax on the area of paint that you've had the solvent on. Do it on a warm day or use a hairdryer to warm it up a little, but don't over-do it.
Old 25th September 2012, 07:48 AM
Here's the 3M cleaner:
http://www.3mselect.co.uk/p-1019-3m-...ray-500ml.aspx
Old 25th September 2012, 07:52 AM
47p2's Avatar
47p2 47p2 is offline
It's almost impossible to re-attach the badges. The sticky pads used us not available as a separate item and impossible to buy, also getting the spacing right is a pain in the neck.
Nite Blue 3.0L SE Quattro
When I put the "correct" boot lid badge back on mine (original design, a bodyshop had lost it and put the later type on ) I used double-sided tape.
Can't recall exactly what type, but it was for car badge/trim/numberplate use. There are different thicknesses, but you do need a certain minimum thickness anyway to ensure a good fit (curved bodywork, flat badge) and mine was probably at least 2mm or 3mm thick - you really don't notice once it's on.
Inspect the back of the badge carefully too, there may be slight recesses for the tape.
And yes I used dental floss on the old one.
As for positioning I consulted loads of photos, brochures etc. etc. and took very careful measurements of blown-up photos.
Old 25th September 2012, 07:55 AM
Something like 3M tape for sticking the badges on mate, and meths or petrol or the unsticking just don't leave it on the paint for too long.
I'm not aware of any dimensions for them but could well be some that one of the Etka hero's might be able to find.
I don't have those badges on mine just the rings and the quattro one but when i first got it it had a boot lip spoiler. When i took it off i left 2 marks in the paint the full width where the tape had been, i did poilsh out in the end but in some lights can still be seen. Just wondering if you can see where they used to be
Old 25th September 2012, 08:11 AM
Yes, I found that when I took the "wrong" (larger) boot lid badge off there was a very faint mark that wouldn't go away. That badge had been applied straight after a respray so I'm guessing the lacquer dried differently.
The correct badge is in almost the same place, though smaller, so you don't notice.
Old 29th September 2012, 08:00 PM
Baryonyx's Avatar
I've spent a good few days gazing out of my front room window at the back of my A8. It looks great as it is, and if I can't get the badges on it I'll still be pleased with it. If I can, that would be great as I love 'factory standard' stuff!
Old 3rd October 2012, 01:51 PM
Jake242's Avatar
Jake242 Jake242 is offline
IMO it looks best debadged... but the rings still needs to be there. As for badge "tuning" then thats a big no no... putting an S8 badge on anything else than an S8 is blasfamy in my book
Audi A8 4.2 quattro D2 94' - THE CARRIAGE
Audi A4 1.6 B5 95' - THE LADY IN RED
Opel Kadett 1,2 C 77' - THE CASKET
