Old 8th October 2012, 10:00 PM
Mutley Mutley is offline
Can you do a side individually to raise at the rear? or have an assistant check. Could be that the shocker itself has gone.
I think it's definitely back left but while I can get this far I'm reluctant to say its def the shock as its a 250 fix, I have however got me head under and checked the level sensor and all seems attached, I don't think it is the level sensor as it detects and changes with height.
Is a shock a DIY ? How does it work swapping airlines etc ?
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
