Old 27th October 2012, 12:01 PM
Also if it was immobiliser problem you would get immobiliser light on dash and and there would be fault code stored in ECU saying engine start blocked by immobiliser or something like that. An you would be able to start engine if you do it straight after switching ignition on and it would run for 1-2 sec. Dodgy camshaft position sensor would also show in fault codes, crank sensor on the other hand often does not show a fault code.
