Old 2nd November 2012, 05:44 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Had a quick go after work.
Double checked the power to the Tuner and Power to the TMC, all ok.
Wired the Tuner up to the RNS with out TMC and it worked.
The RNS unit detected the Tuner and switched to the Tuner. Brilliant.
1 down and 1 to go.
I connected TMC to the RNS via the cables above and the RNS unit could did not detect the TMC.
I double checked the power cables and Canbus cables but nothing.
It all appears to be ok but no connection.
I can't see any reason for the TMC unit not to communicate with the RNS, unless the TMC needs to be connected to the clocks or the unit is faulty.
It started to rain and I had to shut the doors so I gave up with the TMC for now and got the portable DVD player to see if I can get it on the screen.
I pluged the DVD player into one of the yellow sockets and changed the input signal from TV to AV1 and on to AV2 y/c (I think that's it) trying to find it but I was not able to find anything.
I need to do some research about this and about the TMC but that's where I am at the moment.
I'll keep updating how I get on in the hope it helps others.
