Old 3rd November 2012, 10:39 AM
Default gearbox
i had this trouble with my wife car ok in drive then put in reverse it jumped swich engine of and cleaed for a sort time when got it check found out it was the gearbox ecu full of water ,as the floor in car had water leak the cost of a ecu was £1300 pound so the car was scraped.hope your car is not that problem good luck with the scan
Old 3rd November 2012, 03:39 PM
Richierich37 Richierich37 is offline
Dam problem is still there, fine in drive but banging into reverse when selected causing all gear select symbols to be in red boxes! Hope it's not the ecu as above!
Where is the gearbox ecu as I hope it's not in the passenger side floor where my water leak is causing floodage!
Old 3rd November 2012, 03:47 PM
TCU is in the engine bay box next to the fan, so should be less liekly to flood, but could have some water in there.
Old 3rd November 2012, 03:48 PM
ECU is in the (sealed waterproof) box under the bonnet - passenger side in front of bulkhead beside the air intake.
There are several in there; I think it's on top.
Old 3rd November 2012, 04:41 PM
sarg sarg is offline
Sorry to say, but this sounds to me like one of those pesky O rings has gone, which sadly means the gearbox will either need stripping and refurbing, or a reconditioned exchange box.
If that is the case, definitely wouldn't do a fluid change, it won't make it any better, could make it worse, and will cost you about £300 for nothing
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
Old 3rd November 2012, 05:17 PM
thebluewhale's Avatar
Have you got the fault codes from Vagcom yet?
If we know what the fault code is we may be able to narrow it down.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 3rd November 2012, 07:04 PM
Thanks for the replies guys! Its going into the garage on Monday so if any codes show up I will post up for you to see. Its not sounding good though!
Old 4th November 2012, 11:35 AM
Iyole Iyole is offline
Had a similar issue with my A4 Cabriolet. Multitronic Box.
Flashing gear select indicators all at the same time on the dash mean that the
Box ECU needs replacing....
Very costly.... I shipped mine to a company in UK that repair them for a fraction
of the dealers cost for a new one....
2002 S8 D2 F/L
