Old 6th November 2012, 03:56 PM
Default 4.2TDI radiator fan running constantly
I returned home after a week away and my car has developed an issue, basically the radiator fan is running constantly and continues to run for about 30 seconds after I stop the engine.
A quick scan revealed the following code:
Code:
                Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 4E1 910 409 A    HW: 4E1 907 409
  Component and/or Version: 4.2L V8TDI  G000AGMª0070
           Software Coding: 0011773
            Work Shop Code: WSC 00503 503 81333
                      VCID: 22400330FD210608171
1 Fault Found:
006400 - Coolant Fan Control 2
               P1900 - 001 - Open or Short to Ground
I am suspecting an electrical issue, bad contact or corrosion or possibly a faulty module, but before I start taking things apart I wondered if anyone had come across this before?
Old 6th November 2012, 08:35 PM
47p2's Avatar
47p2 47p2 is offline
Could it be caused by low battery voltage?
Nite Blue 3.0L SE Quattro
Old 7th November 2012, 05:45 AM
Sounds like a short in fan control module. Happens to lot of VAG cars across the range.
Old 18th November 2012, 03:58 PM
Well as suggested it was the fan/control module (4E0 959 455 H), replaced with a new one and all back to normal
