Old 7th November 2012, 07:12 PM
thebluewhale's Avatar
Sounds like a result there fella.
The F125 switch might just need cleaning up, even a replacement switch is cheaper than a 'box refurb.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 7th November 2012, 07:43 PM
Richierich37 Richierich37 is offline
Great cheers guys, just called my mate and cancelled the Lambda sensors! Is that the exact code reader for my 2002 car? If so I'll puchase it?!?!?!
Old 7th November 2012, 07:54 PM
not 100% sure, it works with my S8 which is the same year so guess it should, best e-mail the guy to check before buying if I were you
cheers
Old 7th November 2012, 09:14 PM
If it helps, I can dig out the receipt for my F125 replacement earlier this year. There are 2 versions of this thing, one more expensive than the other. My car is also a 2002 S8 and needed the more expensive switch. But as said above, it's cheaper than a gearbox!
Old 9th November 2012, 03:23 PM
Spot on fella, got a call today from my mate saying the wrong F125 was sent and the one I need is around £125! Now won't get the car back till next week as he's away for the weekend!
