Old 12th November 2012, 07:21 AM
So, I've left the central locking alone for a while whilst I focus (hee hee) on the reversing camera installation on the nearside.
First I had to cut a couple of holes in a spare n/s rear light unit to take the boot lock that I'd butchered by removing the lock barrel to take the camera instead (first 2 pics).
The camera is a very neat fit into the empty lock carrier as the second couple of pics show.
But, I had to break off part of the chrome surround as there's a bit that extends down the lock barrel and that meant I had to have the remaining part machined so that the camera would fit flush inside it (pics 5 & 6).
The last 2 pics show the camera inserted into the lock carrier and then positioned loosely into the light unit. I still have to seal it and make it sit a bit more centrally before the light unit goes back into the car, but so far it's looking pretty good I think.
ID:	5251   Click image for larger version
ID:	5252   Click image for larger version
ID:	5253   Click image for larger version
ID:	5254   Click image for larger version
ID:	5255   Click image for larger version
ID:	5256   Click image for larger version
ID:	5257   Click image for larger version
Old 16th January 2013, 09:42 AM
Well, I'm ready to fit this and sort out the boot lock, but I need a connector for the vacuum pipe on the central locking. Does anyone happen to know what diameter the pipe/tube is so I can look for one on ebay?
Old 2nd March 2013, 04:33 PM
Well, nearly there. Central locking now working on the boot lock - many thanks to A8 Parts for the connectors.
But not without some problems. It took a while to find the disconnected vacuum pipe form the boot mechanism. The pipe that I thought it was previously was, in fact, the wiring for the reversing camera. And it was a hell of a job getting an extra pipe through the two grommets - would have been impossible without David's help. Thanks David!
And then, when it was all connected, there was a vacuum leak! Turned out to be the rubber seal on the rod that the mechanism actuates to disconnect the boot lock when the car is locked. Luckily, I had a spare.
So, the central locking works fully and the reversing camera works again (see the photo to show installation in near side light cluster to mirror the boot lock on the off side.
BUT - I put the f*****g camera in upside down!
So, another weekend it'll all have to come out again
Name:	Reversing camera.jpg
Old 2nd March 2013, 04:52 PM
sloss's Avatar
sloss sloss is offline
So it was the camera's fault?
