Old 29th January 2009, 07:47 PM
thebluewhale's Avatar
Question Continuation of S8 Newbie Help from TSN
Hi again
It looks like I've moved to the A8 Forum now!
I'll just explain the original post quickly in case you haven't seen it. The cd multichanger isn't working due to an ipod being connected and then removed by the previous owner.
I've finally managed to remove the Nav Plus (Do not buy the Halfords removal tools! NOT GOOD) and have found a '2 Connects' box with a 9 pin din connector at one end and a 14 pin flat black connector on the other. I am assuming the 9 pin din is the ipod connector in the glovebox I have found.
The flat 14 pin connector is connected to the cd side of the red block connector which connects to the back of the Nav Plus Unit.
I don't know if something is missing or I can't see it (It is 8.30 PM and pitch black!) but I'm not sure where the 14 pin connector goes.
Anybody have any ideas as the wife is starting to complain she can't listen to her cd's in the car
Thanks
Old 29th January 2009, 08:03 PM
Originally Posted by thebluewhale View Post
Hi again
Thanks
Hi, great to see you... !
The original Audi Cd changer cable is blue, and square. It mates up with a yellow and green similar square connector that all clip to one another and plug in above the black 8 pin ISO power connector, and the brown 8 pin speaker connector (if present)
I've used the ipod adapters before, and usually to install them, you just unplug the blue CD changer cable and insert their gubbins.
All the ipod equipment you have, right upto the connector on the Sat Nav I would take out and bin/sell/put safe somewhere (delete as you will).
You need to have a good grovel around in the space behind the Satnav and find the original CD changer cable. The factory CD cable is bound in the other audio looms, so it can't have gone too far, I'm sure of it....
Old 1st February 2009, 01:13 PM
Thanks for your response.
I've now managed to have a good look in the light of day and the wiring has been modified. I have attached a couple of pics showing the arrangement.
Is this something I can do myself or will I need an audio specialist?
By the way anybody know what the Nokia box is?
ID:	28   Click image for larger version
ID:	29   Click image for larger version
Old 1st February 2009, 01:29 PM
The Nokia box is a handsfree kit. Does the car still have the cradle, as I don't think that one is handsfree.
You could remove it and the adapter loom it's wired into (the one with the two red ends) and that may fix the problem. Or at least make it easier to diagnose. Just unclip the connectors and put the original 3 blocks into the head unit again.
Old 1st February 2009, 01:40 PM
Yup, I agree ^^^^^^^ - Remove the bypass loom withthe two red connectors, and instead plug the blue/yellow/green connector straight into the Nav unit. This will almost certainly bring your CD changer back to life.
The nokia is a hands free kit, but I suspect the computer-lan type RJ45 connector either does, or did go to a cradle. Unless you want to preserve the nokia functionality, then it could be removed if you trace the various wires and remove them too....
Old 1st February 2009, 03:58 PM
It Works!
Thanks a lot for your help. I now have a working multichanger and a happy missus!
Old 1st February 2009, 03:59 PM
ps Anybody want to buy an ipod connector!
