Old 13th June 2009, 02:42 PM
C5 S6 would do it. Need Rear Diff as well. Custom prop and fabricated pedal cluster and clutch actuating system.
Easier still a written off LHD S8 6 speed from the continent. (By easier I mean still fecking hard)!
Old 14th June 2009, 03:09 AM
C5 S6 has the same ZF auto as the A8, didnt come in manual at least not in the UK for sure..
Old 14th June 2009, 10:30 AM
jmw748 jmw748 is offline
Before my gearbox rebuild, Ian found me a few manual 6 speed boxes on Ebay Germany. All around the 1K to 1.5K Euros cost. With all the other work involved to make the car manual, I plumped for a guaranteed gearbox rebuild!
Old 14th June 2009, 12:32 PM
CliveH's Avatar
CliveH CliveH is offline
How does the cost of a rebuild compare to fitting another one?
Is this a better route to go as presumably a rebuilt box, if serviced properly, will last for a long time whereas there is no guarantee how long a used one will last or how it was cared for in the previous car?
Old 14th June 2009, 01:53 PM
Rebuild is about the same price as getting a swap for a remanufactured job.. about 2k fitted.
Old 17th September 2009, 07:00 AM
Siena
Guest
Posts: n/a
The 01E / 01X 6-speed manual bolts directly to any V8 block - 3,6, 3,7 4,2L 32/40V without any issues.
The manual transmission, both 01A 5-speed, and 01E 6-speed are multi-fitment, i.e will bolt to ALL Audi blocks, from I4 to V10. The only exception as far as V8 fitment goes, is the C5 RS6, which due to the massive torque converter (shared with the the W8 VW Phaeton) means the block has a different bolt pattern to regular V8's, and requires a slightly different approach to run an 01E.
Old 17th September 2009, 11:04 AM
What model where the 01E 6-speed boxes fitted to? Any for sale?
