Old 15th December 2012, 07:59 PM
manca manca is offline
Thanks I'll have a check through everything tomorrow .
Richard - Thanks same drop off as collection, I'll PM if Wednesday looks dubious, but I'm sure it will be fine .
Adam
Old 16th December 2012, 03:00 PM
Today I appear to have a fully functional sat nav again although I gather any issue relating to this is separate to the MMI update.
I don't have Bluetooth though. MMI tells me I have no phone, my sgs3 cant detect the Audi module. This seems to be related to the update as it was working fabulously beforehand. There doesn't appear anything i can do. I have tried pairing using two other phones but they aren't detecting the Audi unit, and of course the MMI says there's nothing installed anyway.
Could this be recoverable via Vagcom....or is the unit toast....has anyone got any experience .
I have tried running all the discs again, none of them are picking up anything to update. I must have attempted to run disc 2 about 10 times (in different slots on the changer as well) but no joy.
TIA
Adam
Old 16th December 2012, 03:19 PM
Smile
Well I am back in the car for the fourth time. Two attempts with cd2 in slot 1 of the changer did nothing. Then slot2 immediately picked up an update for Handyvorb2/MAIN6/App to upgrade rom 0 -1130. Fingers crossed.......
Old 16th December 2012, 04:47 PM
Fingers crossed
Old 16th December 2012, 04:54 PM
Success
Old 1st February 2013, 08:01 AM
wug wug is offline
Okei, i have updated to 5570 version but i cannot see the Battery Level. Any suggestions?
Old 1st February 2013, 10:25 AM
you need to turn it back on - it gets taken of as standard in the latest version as it was thought to be not that good
to turn it on you need access to the hidden menu
you only have access to the hidden menu if its been enabled in vagcom
try it though you may be lucky
You press CAR + SETUP at exactly the same time and hold for a few seconds until a green hidden menu appears
once your in go to car menu mask
then scroll down to find the battery meter
click it so a tick appears
scroll down and save
reboot using TEL - MAIN BUTTON and top right button
and it should be there
be careful using anything else in the hidden menu it can be dangerous
Old 1st February 2013, 12:54 PM
wug wug is offline
Alright, i have tried several times CAR + SETUP but nothing happens. Seems like i have to activate it with VCDS. I have VCDS interface but i don't know how to activate the hidden green menu.
Also i have seen that the parking sensor are being audible only but not showing on the display. Perhaps using same hidden green menu i can bring this feature to life as well.
Many thanks!
Old 1st February 2013, 12:59 PM
not sure about the parking, will take a look
heres the vcsd bit
http://www.audi-resource.com/mmiaccess.php
Old 1st February 2013, 01:03 PM
there is something about parking in there
under DIAG SETTINGS
then APK 0×01, 0x0B, 0x0C
these 2 settings - you can also do it in vagcom
APS (front) - activation parking sensors front of the vehicle. Equivalent adaptation module 07, channel 1, the value 4
APS (rear) - activation parking sensors in the rear. Equivalent adaptation module 07, channel 1, the value of the 8th
