Sounds very reasonable. Was looking at another thread earlier where it says that Audi charge 'only' £660 for a full cambelt service.
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
![]() ![]() Last edited by A8_Tony; 17th June 2009 at 08:02 PM. |
Be very careful when choosing who does your belt. The A8's belts (V6 or V8) need the tension setting whilst the cams and crank are locked in position but the pulleys can turn freely. This ensures the belt tension is correct whilst still maintaining perfect cam timing. If the belt is fitted without doing this, when the belt tension settles on it's first revolution, the cam timing goes out! And with inlet cams that can vary thier timing by upto 30degrees in operation that's BAD!!!!
Best case is the car loses power and just feels a bit weak and fuel consumption increases, but worst case is clipped valves! If there are tip-ex marks that line up the outside diameter on your timing belt pulleys with the black metal cover behind them that's a sure sign it's fitted wrong wrong! |
Conan - Those guys in cambs any good ??? Have you used them ???
Tony - AVP dead link....looks like its missing a .com / .co.uk or similar ! Lee |
![]() Don't forget if you're a signed up member of the A8OC you get 15% discount on parts & labour from AVP ![]() |
Sorry I have never used them.
