Well, Unlike Sloss's problem a year or so ago, I have neither my heated rear screen working nor my door mirror heaters working
![]() When you press the "demist" button on the control panel (in the car) the little amber "active" light comes on and then times off as it should-but it does diddly-squatt??? ![]() Am I missing something??? ![]() ![]() ![]() Any help greatly appreciated before this cold snap sets in??? ![]() Bex
07 Silver D3 A/S8L Quattro ![]() ![]() |
Bex,
As the little warning light comes on that means there is lecky to the switch. That switch then energised a Relay which then feeds the rear window heater. I don't know where that Relay lives but once you get to it see if it latches, if so then see if the load side ie the window shows continuity. It may not be as simple as that with radio aerials etc embedded but then it's an '8 ![]() Stew, |
It's a difficult thing to check on your own lol. I think the relay is 1 of 3(ish) by the large fuse above the battery??? If anyone could possibly confirm this I would be eternally grateful. ![]()
Relay No.1 in the attached image
. Nite Blue 3.0L SE Quattro |
![]() Bex, With a helper you should feel the Relay energise with switching it on and off. If it does energise then check for live on Load side - if OK then look for fault in window wiring. On your own with a meter it's still easy enough to check. With everything off check all the Relay terminals for live - probably none. Switch on Ignition and check again - 12v on supply side of Relay only. Operate window heater switch - live onto Relay trigger and load side also comes live. If all that works then it's likely to be the window itself - broken connection somewhere or knackered screen wires. In that case switch it all off and check for continuity from load side of Relay. Take either side to earth to see if Window wires are OK. If that shows open circuit then brick the window and claim on Insurance... ![]() |
Thanks for all help ![]() I shall let you all know how I get on (as per usual lol) ![]() ![]() ![]()
