Old 13th January 2013, 12:28 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Super. Thanks Guys Any way of getting the update to run the blue ATF in the south east without going to a main dealer
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 13th January 2013, 12:06 PM
carterleeds carterleeds is offline
yep its only dealer that can flash your gearbox, vcds dont work and no one out there seems to be able to atm. well thats what ive been told. but i dont really see the difference in fluids anyways especially if im putting brand new fluid in.
Old 13th January 2013, 07:48 PM
Something to do with the friction modifiers and the torque converter (TC) regulator clutch. This gearbox can have TC open, TC closed, or TC regulated (slipping). Around town the clutch is designed to be slipping most of the time and I have read it can judder or make a noise with the wrong fluid. I don't think there's anything wrong with trying another fluid as long as it drives the same or better than before.
Old 14th January 2013, 09:39 AM
sarg sarg is offline
my experience of doing this on a D2 is that you need roughly TWICE the capacity to flush out the old fluid properly as you will lose some of the new fluid flushing out the old - it's impossible to only flush out old fluid, so I'd say you need to buy double the capacity
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 14th January 2013, 11:01 AM
http://www.incarmotorfactors.co.uk/t...-fluid-1l.html
Here seems cheap for ZF LG6 fluid, they also do a Febi and a Meyle which are cheaper and claim to be the same.
Old 14th January 2013, 11:58 AM
oh no sorry i meant, once the original fluid was changed out for the same new fluid, it dosent make a difference as to what quality or type, because the fluid would be new so working to best it can. like replacing the gold fluid for the blue, wouldnt make a difference in my eyes due to the fact that whenever new fluids are replaced they work awesome lol. well thats my opinion.
like when i change engine oil on my 04 polos, i put cheap oil from your local parts shop because i make sure it gets changed every year regardless, so by the time the goodness has ran out, ive already changed it. you could say better oil less changes but its just like audi saying lifetime ATF never needs to be changed.
however i did put castrol sport in my mini because of the power and that still gets changed out every year, and in my m3 i used millers which is the best but i still changed that out twice in the year i had it.
i guess you can just tell when it needs doing and what works best tbh. so i guess if people find blue is better than gold without trying new gold in the first place thats just dopy. however if they have tried gold and then moved to blue and feel a difference then good for them.
hope i cleared that up lol
and as for these gearboxes bludy hell is all i have to say lol
Old 23rd January 2013, 07:22 AM
I have a voucher from a8 parts for a service kit oil and filters ect.. But i have not long done a full service. I wander if they will give me a gearbox service kit instead. Must work out the same price wise on a w12 as
Old 23rd January 2013, 07:49 AM
Bear in mind W12 gearbox oil is significantly more expensive than regular stuff, so your sums might not quite add up.....
Old 26th January 2013, 06:54 AM
Thats cheap !!
So is the W12 oil really that much more expencive is it ? Whats the difference .... It has the same gear box as the V10 S8 ....is there special ATF then for the s8 and W12 compared to the 4.2 ?
Old 20th February 2013, 05:29 PM
GlynH GlynH is offline
Would like to get my 2005 W12 gearbox serviced as she's done nearly 150k now!
For the hard of understanding can someone please detail the exact fluid needed and roughly how much I will need?
And what other consumables might I need, gasket(s), filter, etc.
Oh and part numbers for everything would be perfect!
Thanks & kind regards,
-=Glyn=-
