Go Back   A8 Parts Forum > A8 D2 > D2 - Common Faults
D2 - Common Faults Quick links to all known common faults and their solutions
Old 21st January 2013, 01:07 PM
What are the 'marker lights'? I tried this with the ignition on (but engine not running) and it seemed to work. Initially nothing, until I turned the kick down switch on - then it did just as you said.
Old 21st January 2013, 01:13 PM
Lights stalk one step up
Interesting. Perhaps I didn't notice something
Old 21st January 2013, 07:10 PM
Marker lights are simply having your lights set on the sidelight setting / sidelights on Jim, so that the switchgear all glows red
Old 22nd January 2013, 07:10 AM
Yes, it works like Sergie said. Mine was switched off - can't wait to give it a try!
Old 16th February 2013, 10:35 PM
stig1983 stig1983 is offline
Mine has got to be turned off as it won't kick down. Ill be checking this in the morning and hope that its just in the off position.
Old 17th February 2013, 12:05 PM
It works now to watch the MPG go down
Old 17th February 2013, 02:21 PM
Definitely the cheapest, easiest and quickest performance upgrade... . Fuel consumption only gets worse when you use it
Tags
facelift a8 d2 kickdown
