Old 21st January 2013, 01:13 PM
>> What are the 'marker lights'?
Lights stalk one step up
>> I tried this with the ignition on (but engine not running) and it seemed to work
Interesting. Perhaps I didn't notice something
Old 21st January 2013, 07:10 PM
Marker lights are simply having your lights set on the sidelight setting / sidelights on Jim, so that the switchgear all glows red
Old 22nd January 2013, 07:10 AM
Yes, it works like Sergie said. Mine was switched off - can't wait to give it a try!
Old 16th February 2013, 10:35 PM
stig1983 stig1983 is offline
Mine has got to be turned off as it won't kick down. Ill be checking this in the morning and hope that its just in the off position.
Old 17th February 2013, 12:05 PM
It works now to watch the MPG go down
Old 17th February 2013, 02:21 PM
Definitely the cheapest, easiest and quickest performance upgrade... . Fuel consumption only gets worse when you use it
Old 24th December 2016, 05:14 PM
johnny_quattro's Avatar
Default Blinking flip!
Well, resurrecting an age-old thread from back in the mists of time...
I checked mine this afternoon by flooring it in 3rd gear whilst in Tiptronic aka manual mode. Nothing. Not a sniff. Pulled over to the side of the road, turned my knob clockwise (ooo-errr) about an eighth of a turn. I pulled back into a line of traffic and waited a bit before sinking my right foot to the floor. All I can say is that my silver QEII left her berth at a very rude rate of knots and that's probably an understatement. I will admit to being a little bit scared when the gearbox lumped it into first gear (from third gear at 30mph) as it pretty much red-lined straight away.
I am sure that I won't be using this facility on a regular basis but will leave it enabled. It has always struck me how lethargic the auto box can be, especially when you want to get a move on. If I ever have a situation where I can safely 'boot' it in order to avoid a possible accident, it is now possible to extricate one's self out of harm's way. Thank you for this beautiful nugget of old information. It was certainly news to me.
Tags
facelift a8 d2 kickdown
